Sharing maintenance tips & tricks
Countless time-conserving, money-saving, aggravation-avoiding ideas for solving typical plant maintenance problems are used by Plant Engineering readers.
By Ron Holzhauer March 1, 2000
Countless time-conserving, money-saving, aggravation-avoiding ideas for solving typical plant maintenance problems are used by Plant Engineering readers. Unfortunately, all too often the knowledge base of these inexpensive, easy-to-implement problem- solvers is not universal.
Sharing simple, shortcut maintenance methods or procedures with others in the profession is the basic intent of Plant Engineering magazine’s annual “Tips & Tricks” article. Reader- submitted maintenance suggestions selected by our review committee will appear in the August issue. Those not picked for that article will be considered for use in our monthly “Simple Solutions” department.
In addition to submitting the maintenance ideas, we want our readers to pick the “best” tip of the year 2000 from among those published. A reader service number will be assigned to each entry so that you can vote for the five you think are the most appropriate or practical for solving your plant engineering maintenance problems.
The highest vote getter will reward the submitter with $1000. The two runners-up will each receive $250. All items published in “Tips & Tricks” or “Simple Solutions” will earn the submitter $35.
Entering the contest
Look around the plant, or call on past experiences. Do you see a short-cut method for handling a maintenance problem, or recall a technique that worked well in the past? The ideas do not have to be a big deal, or even original. What is common knowledge or routine in one plant, industry, or area might be “new” elsewhere.
If you come up with a good idea, send us a detailed explanation. State the problem that existed, and then present the solution provided by your tip. Drawings or color photographs visually depicting the ideas are extremely important to the impact and understanding of the idea. Also include a professional biography, company mail and/or e-mail address, and daytime phone number.
Send your submittals to Ron Holzhauer, Plant Engineering magazine, 2000 Clearwater Dr., Oak Brook, IL 60523. Ideas can be e-mailed to rholzhauer@cahners.com or faxed to 630-320-7145.
Entries must be received by April 17 for consideration.
