Seven items to address with your process hazard analysis
Process hazard analysis (PHA) should provide information that will improve safety and reduce danger from hazardous chemicals. Here are seven items your PHA must address.
A process hazard analysis (PHA) is just one of the 14 essential process safety management (PSM) elements, but it’s also one of the most important. A PHA is extremely detailed, designed to examine and address potential hazards associated with handling highly hazardous chemicals. Do you have all of your bases covered?
About PHA
Your PHA should provide information that will assist in your plant’s decision making about improving safety and reducing the consequences associated with hazardous chemicals.
A PHA analyzes potential causes and consequences of:
- Fires
- Explosions
- Releases of toxic or flammable chemicals
- Major spills of hazardous chemicals
A PHA focuses specifically on:
- Equipment
- Instrumentation
- Utilities
- Human actions
- External factors that might affect the process
The Occupational Safety and Health Administration (OSHA) requires PHAs to be updated and revalidated every five years. However, you must update your PHA whenever you alter an item that affects your process. This could include anything from the introduction of new equipment or substances to the elimination of existing equipment or any change that could introduce a new hazard.
When your PHA is examined, an auditor takes about two days at your facility, posing questions to your plant’s refrigeration personnel and engineering teams.
The ‘what if’ methodology
With a PHA, you’re responsible for your own answers. There are a few methodologies you can use when evaluating your process hazards; however, Stellar has found that the “what if” methodology historically works best (as it is faster) for the ammonia refrigeration industry. Through the “what if” approach, “what if” questions are posed about hazard scenarios to elicit answers that show how your plant would address them.
Here’s a sample “what if” question/scenario and answer about a valve.
Question: What if the packing fails on the valve?
Answer: I have trained operators and a PM program. Personnel makes rounds each day to inspect for leaks.
7 items to address in your PHA
After you’ve determined your methodology, you should ensure your PHA addresses the following seven items outlined by OSHA:
- The hazards of the process
- The identification of any previous incident that had a likely potential for catastrophic consequences in the workplace
- Engineering/administrative controls related to hazards, such as the application of detection methods for early warning of chemical releases (Acceptable detection methods might include process monitoring and control instrumentation with alarms, and detection hardware such as hydrocarbon sensors)
- Consequences of failure of engineering and administrative controls
- Facility siting (the location of various components within the facility)
- Human factors
- A qualitative evaluation covering the range of possible safety and health effects on employees stemming from control failures in the workplace.
This article originally appeared on Stellar’s Food for Thought blog. Stellar is a CFE content partner. Edited by Joy Chang, digital project manager, CFE Media, jchang@cfemedia.com
Original content can be found at stellarfoodforthought.net.
