Servo adaptor
The compact design of the Lenze servo adaptor provides a more compact and cost-effective solution than using a standard input flange connection from a gearbox to a servo motor.
The compact design of the Lenze servo adaptor provides a more compact and cost-effective solution than using a standard input flange connection from a gearbox to a servo motor. The Lenze g500 gearbox series features energy efficiency of at least 94 percent across the entire transmission range. Lower energy use translates into cost savings and less heat generated, which can increase the overall service life of a motor.
Lenze Americas
