Continue to Site
Serial interface converters
The SC-232 series converters feature Send Data Control (SDC) which automatically enables the RS485 driver when data is present on the RS-232 side.
August 28, 2014
The SC-232 series converters feature Send Data Control (SDC) which automatically enables the RS485 driver when data is present on the RS-232 side. Additional features are port power and Opto-isolation on some models.
Each converter ships with a DB9 female to screw terminal block adapter for connection flexibility. The converters operate at temperatures 40°C to +85°C and have point to point 2-wire half duplex support as well as point to multi point 2-wire half duplex operation The converter has port powered options and opto-Isolation options.
L-com
www.l-com.com
