Seal protects bearings
Air Mizer and VBXX bearing isolators are used with machine tool spindles and other high-contaminant applications. They protect bearings from coolant, chips, humidity, and heat. A reverse interface prevents direct impingement of moisture and contaminants.
Air Mizer and VBXX bearing isolators are used with machine tool spindles and other high-contaminant applications. They protect bearings from coolant, chips, humidity, and heat. A reverse interface prevents direct impingement of moisture and contaminants. Humidity ingress is eliminated when the spindle is at rest.
Inpro/Seal Co.
