Screwdriver with LED lights
The 2-Position Ratcheting Screwdriver with LED light technology has two LED lights and a 45-tooth ratcheting mechanism with forward, reverse and locked positions to quickly tighten or loosen fasteners
May 16, 2013
Courtesy: Brett Sayles
The 2-Position Ratcheting Screwdriver with LED light technology has two LED lights that help illuminate a poorly lit work area. The screwdriver has a 45-tooth ratcheting mechanism with forward, reverse and locked positions to quickly tighten or loosen fasteners. The screwdriver features a stainless steel collar that magnetizes the bit tip to help hold fasteners on the tool, resulting in fewer dropped and lost fasteners. With the 2-position handle, users can choose the position that is the most comfortable without sacrificing leverage. The 4 ½-in. shaft provides greater access for end users.
GearWrench
www.gearwrench.com
