Screw conveyor package
The Screw Conveyor Package (SCP) is designed as an alternative to screw conveyor drives and features speed reduction ratios and a coupled gearmotor to reduce the need for additional parts.
By Nord Gear Corporation August 10, 2015
The Screw Conveyor Package (SCP) is designed as an alternative to screw conveyor drives and features speed reduction ratios and a coupled gearmotor to reduce the need for additional parts. Courtesy: Nord Gear CorporationThe Screw Conveyor Package (SCP) is designed as an alternative to screw conveyor drives. Features include speed reduction ratios combined with a coupled gearmotor that eliminates the need for motor mounts, pulleys, belts, or guards. The screw conveyor drive options include a Unicase reducer housing, Quadrilip reducer shaft sealing, and output bearings with flange mounting and drive shafts ranging from 1-1/2-in. to 3-7/16-in. A lead taper on the reducer shaft provides mounting and removal, which allows for some screw pipe misalignment and reduced bearing loads.
www.nord.com
