Rubber hydraulic hose
Twin Tough bonded rubber hydraulic hoses are designed to eliminate the labor required to bundle two separate hoses with tie straps or plastic sleeves. The line is available in four variations, each in 25 and 50-foot lengths and each featuring a one-half SAE 100R1/100R2 minimum bend radius. The 451TC variety offers a 3,000-psi constant working pressure in 3/8-inch and 1/2-inch sizes, with a one-...
By Staff October 15, 2007
Twin Tough bonded rubber hydraulic hoses are designed to eliminate the labor required to bundle two separate hoses with tie straps or plastic sleeves. The line is available in four variations, each in 25 and 50-foot lengths and each featuring a one-half SAE 100R1/100R2 minimum bend radius. The 451TC variety offers a 3,000-psi constant working pressure in 3/8-inch and 1/2-inch sizes, with a one-wire-braided construction. The 471TC variety features constant working pressures of 5,000 and 4,250 psi in 3/8 and 1/2-in sizes, respectively.
Parker Hannifin Corp.
www.parker.com
