Rod locks
The RLSS Rod Locks feature a wide clamping surface to ensure high holding forces even during power/pressure loss, providing reliable precision gripping of up to 5,026 pounds, depending on the model. They ensure accurate positioning and holding while other operations are performed. The rugged rod locks use numerous ball bearings to transfer the spring force onto the clamping collar, resulting in...
By Plant Engineering Staff June 1, 2009
The RLSS Rod Locks feature a wide clamping surface to ensure high holding forces even during power/pressure loss, providing reliable precision gripping of up to 5,026 pounds, depending on the model. They ensure accurate positioning and holding while other operations are performed. The rugged rod locks use numerous ball bearings to transfer the spring force onto the clamping collar, resulting in large clamping areas designed to provide a uniform force to the contact area on every engagement. This allows the lock to engage without any rod displacement.
Nexen , info@nexengroup.com .
