Removable steel bollard
Model BOL-OR-40 is a functional, ornamental steel barrier to vehicle access and parking. It locks into a galvanized steel socket that is cemented into the ground. When the bollard is removed, a socket cover protects the hole, leaving no protrusion above the surface. The unit has a usable height of 40 inches, a diameter of 5 ½ inches and a weight of approximately 84 pounds Vestil Mfg.
Model BOL-OR-40 is a functional, ornamental steel barrier to vehicle access and parking. It locks into a galvanized steel socket that is cemented into the ground. When the bollard is removed, a socket cover protects the hole, leaving no protrusion above the surface. The unit has a usable height of 40 inches, a diameter of 5 Vestil Mfg. Corp. : www.vestil.com
TO VOTE, WRITE 145 ON BALLOT
For more information, write 145 on card
