Continue to Site
PVC coated sealing locknut
Plasti-Bond's PVC coated sealing locknut provides protection for exposed conduit threads from corrosion.
By Plasti-Bond June 27, 2017
Plasti-Bond’s PVC coated sealing locknut is a simple, detachable sleeve providing a consistent seal over exposed conduit threads at the point of connection, designed to prevent thread exposure. Its features include:
  1. Built-in gasket at the face of a locknut to provide a positive seal against water, oils, and other liquids against the hub of a connected fitting
  2. An integral sleeve on the reverse side of the locknut designed to fit securely over the circumference of the adjacent coated conduit
  3. Extra thin construction which allows the sleeve to thread on only 2-1/2 threads leaving at least seven threads for complete engagement of the conduit to its connected fitting
  4. Gasket and sleeves made of specially formulated and UL-recognized PVC materials, tested for aging-resistant, compressive ,and tensile properties.
  5. A simple design which allows for easy installation and tightening over conduit threads at joints throughout the system. The tools required for tightening include a strap-wrench and lube to assist the fitted sleeve over PVC-coated conduit. By eliminating product failure, the staggering cost of downtime, safety hazards, replacement costs, and related liabilities are eliminated.
Plasti-Bond
plastibond.com
– Edited by Carly Marchal, content specialist, CFE Media, cmarchal@cfemedia.com.
