Protector strip for low-voltage cabling
By Plant Engineering Staff May 2, 2007
Protector Strip provides physical protection for non-metallic sheath cables or low-voltage cabling hidden in shallow recessed walls. The Protector Strip can also be used in exposed or concealed locations. It is designed in accordance with 2005 NEC article 300.4 (B)(2), article 334.15 (B), and other cables per article 300.4(D) and (E). In addition, the Protector Strip features slots to secure cables as required by NEC article 334.30. Each protector strip comes in a 3-foot length section and is made of zinc electroplated 0.063 inch thick steel.
Bridgeport Fittings, Inc.
http://www.bptfittings.com
