Product Intros – 2002-05-13
By Staff May 13, 2002
Cable carrier zips open
R09 fully enclosed cable carrier is used to guide and protect moving cables and hoses. It offers lightning-fast assembly and inspection time with its zipper lid design. The lids offer full protection against wood and metal chips. The carrier holds cables up to 1/2-in. diameter and is suitable for use on machine tools, material handling devices, and other industrial equipment.
igus, inc.
igus.com
Write 371 on PE card
Direct drive compressor maximizes efficiency
DSD and ESD series direct drive rotary screw compressors are available in flows from 382 to 1490 cfm and pressures to 217 psig. These units feature an optimized Sigma Profile airend, Sigma control system, and the latest one-to-one direct drive technology. A unique cooling airflow design significantly reduces noise levels.
Kaeser Compressors Inc.
kaeser.com
Write 372 on PE card
Stick/TIG welder is lightweight
Maxstar 140 STR is a DC Stick/TIG inverter machine that weights only 10-lb. It has a 5 to 140 amperage range, which is a 100% duty cycle at 140 amps and 230 V input. The unit’s Auto-Link feature allows the operator to plug the unit into 115 V or 230 V primary power without removing the cover to re-link the power source.
Miller Electric Mfg. Co.
millerwelds.com
Write 373 on PE card
Sensors designed for hazardous locations
Non-incendive 430 Series pressure transducers and transmitters are designed for optimal protection in hazardous environments. There are three models: Series 433 is a 5 V transmitter, Series 436 is a 10 V transmitter, and Series 435 is a 4-20 mA transmitter. All models handle pressure ranges from 0-15 and 0-10,000 psig, vacuum, 0-15 and 0-300 psia, and temperatures from -40 F to 185 F.
Barksdale, Inc.
barksdale.com
Write 374 on PE card
Controller has many inputs and outputs
Model PXR3 controller offers a wide variety of inputs and outputs and a 16-segment ramp-soak profile. Low-cost options include RS485 Modbus communications with free Windows-based software, digital input, dual outputs, and programmable alarms.
TTI, Inc.
ttiglobal.com
Write 375 on PE card
Security cart has double door front
RC-8 Security Cart is 48 x 24 x 70 in. and has a double door front with a patent pending EZ Latch N Lock system. The side mesh is 21/4 x 21/4 in. mesh and the base is 1 x 4 in. mesh. The heavy-duty base has casters inset and bolted to welded plates for durability.
Carico Systems
caricosystems.com
Write 376 on PE card
Controller connects to Internet
iSeries temperature/process controllers connect easily to an Ethernet network with a standard RJ-45 connector and can send and receive data in standard TCP/IP packets. These devices can serve web pages over an Ethernet LAN or over the Internet, making it possible to monitor and control a process through a web browser from anywhere in the facility or the world.
Omega Engineering, Inc.
omega.com
Write 377 on PE card
Collect data on forklifts
DataRanger is a data collection device designed to assemble event data from fleets of forklifts equipped with an ID impact monitor. The device allows a manager to access and download information stored in any ID on any forklift anywhere within the facility.
Shockwatch, Inc.
shockwatch.com
Write 378 on PE card
Move heavy loads
Aero-Casters are used to move heavy equipment on a thin film of air supplied by standard shop compressed air, virtually eliminating friction and the problems with rollers and casters. Moves can be omni-directional and positioning is easy in tight spaces, eliminating floor damage.
AeroGo, Inc.
aerogo.com
Write 379 on PE card
Pump control saves energy
Model PS 200 is microprocessor-based, variable speed drive programmed specifically for centrifugal pumps up to 700 hp. Energy savings in the 30 to 70% range are obtained because, at lower demands, the control reduces motor speed, eliminating the extra energy used to overcome the pressure drop of control valves.
ITT Industries Goulds Pumps
gouldspumps.com
Write 380 on PE card
Soft starter saves space
Intelligent Technologies (IT) Soft Starters are 30% to 80% smaller than other starters. They can be used in place of electromechanical starters, contactors, and some drives. The design integrates the bypass contactor and overload relay into one compact unit. This eliminates the need for separate, hard-wired devices, saving panel space and wiring costs.
Cutler-Hammer Div. Eaton Corp.
cutler-hammer.com
Write 381 on PE card
Cylinder provides conveyor stops
EFI cylinder features a hard-coat anodized, PTFR-impregnated cylinder body and space-efficient overall size and is designed for rugged conveyor stop applications. The rod end has been modified with a heavy-duty mounting flange anchored by four, high-strength bolts. Impact load resistance is 65 lb at 8 ips. Standard strokes are 10, 15, 20, and 25 mm.
Bimba Mfg. Co.
bimba.com
Write 382 on PE card
Synchronous belts match most drives
WhiteHawk Pd and BlackHawk Pd synchronous belts offer unmatched compatibility with other belts, high horsepower loads, and reduced drive widths. WhiteHawk’s 8-mm and 14-mm pitch belts are available in 20 to 170-mm widths and 480-mm to 6.86 meter lengths. BlackHawk’s 8-mm and 14-mm pitch belts are available in 12 to 120-mm widths and 480-mm to 4.956 meter lengths.
Goodyear Power Transmission Products
goodyearptp.com
Write 383 on PE card
IR thermometer has laser pointer
Model 42529 IR thermometer measures surface temperature, without contact, in a range from zero to 600 F. It offers a large LCD with backlighting for easy viewing in dim light. The built-in laser pointer targets the area to be measured. The narrow field of view measures a 1-in. target at a 6-in. distance. Fixed emissivity (0.95) covers 90% of surface target applications.
Extech Instruments
extech.com
Write 384 on PE card
Wire stripper does more
Kinetic Super wire stripper merges a suite of cutting edge features to deliver the ultimate in comfort, performance, and safety. It is available in a wide variety of designs for accurately cutting and stripping all common wire gauges, as well as for slicing through bolts and nuts.
Ideal Industries, Inc.
idealindustries.com
Write 385 on PE card
Switch handles portable power
Portable power distribution units are designed to fit electrical needs in emergency power or other temporary power applications. Features include: NEMA-rated breaker load panel with switch-rated receptacles and power capacity from 20 to 600 amp. Units can be configured to customer specifications, and can be moved with a crane or forklift.
Meltric Corp.
meltric.com
Write 386 on PE card
Machine monitor uses acoustics
Acoustic Machinery Monitor evaluates sounds produced by rotating machinery, non-rotating equipment, and processes to detect problems as they develop, before they result in failure. Using 96 frequency bands, the monitor has the ability to learn and analyze what a machine or process sounds like during normal operation and sound an alarm when deviations occur.
Intonix Corp.
intonix.com
Write 387 on PE card
Level detector has high accuracy
MT2000 is a guided-wave, radar level transmitter that measures the level of bulk solids and liquids under harsh conditions with an accuracy of
K-TEK
ktekonline.com
Write 388 on PE card
Heat camera views and records data
ThermaCAM P60 IR system features thermal and visual imaging, a built-in Laser LocatIR, a detachable carrying handle with integral remote control and 4 in. LCD, JPEG image storage, enhanced connectivity options, and powerful software.
FLIR Systems, Boston
flir.com
Write 389 on PE card
Ultrasonic monitor warns and trends
Ultra-Trak 750 passively monitors structure born ultrasounds produced by operating equipment. It can be set to detect either a rise or drop of sound levels in real time for alarm or trending purposes. Typical applications include early warning of mechanical failure, valve leakage, cavitation, and arcing in enclosed switchgear.
UE Systems, Inc.
uesystems.com
Write 390 on PE card
Related Resources
