Process controller in 1/8 DIN package
This panel-mount controller is available in a 1/8 DIN size with choice of horizontal or vertical configuration allowing it to fit variable cabinet profiles. The controller features large characters and buttons, which improves usability.
July 29, 2009
Watlow EZ-ZONE PM panel mount controller
The EZ-ZONE PM panel mount controller is now available in a
new 1/8 DIN size with choice of horizontal or vertical configuration allowing
it to fit variable cabinet profiles. The controller features larger characters
and buttons, which improves usability. The product’s new case slots make it
easier to remove the control hardware from the front-pluggable DIN chassis
using a screwdriver. Controller functionality includes dual-channel PID
control, cascade control, square-root linearization, wet bulb/dry bulb capability,
ratio and pressure-to-altitude compensation curves. The controller also has the
ability to run a single profile ramp-soak program on dual channels
simultaneously.
The controller product line is comprised of integrated
thermal loop controllers.able to support connectivity
needs.
Watlow
www.watlow.com
