Probe measures voltage and current
The 348SP shaft probe makes it convenient to measure the levels of voltage and current present on rotating motor shafts.
The 348SP shaft probe makes it convenient to measure the levels of voltage and current present on rotating motor shafts. The shaft voltage/current probe determines whether levels are excessive enough to contribute to premature bearing failure through electrical discharge machining (commonly known as fluting, frosting, or spark tracks). CSI
