Printer doubles output
The 580 pad printer meets high-volume needs by outputting quality marks at significantly higher speeds than comparable products. A solid-state, PLC-controlled system and enhanced air cylinders enable the printer to produce up to 60 parts/min.
By Staff March 1, 2000
The 580 pad printer meets high-volume needs by outputting quality marks at significantly higher speeds than comparable products. A solid-state, PLC-controlled system and enhanced air cylinders enable the printer to produce up to 60 parts/min. The 50% greater pad compression strength allows the printer to create accurate marks with better quality. Other features include simple setup, operation, and maintenance.
Markem
www.markem.com
Circle 394
