Pressure transducer
The Compact 3100 series pressure transducer features a footprint of less than 1 inch in diameter and stainless-steel construction. The transducer’s ASIC design offers accuracy to 0.25% full scale, long-term stability of 0.1% per year and thermal stability that is accurate to within 1.0% per 100 F over the compensated temperature range of -40 to 250 degrees F.
By Plant Engineering Staff September 15, 2007
The Compact 3100 series pressure transducer features a footprint of less than 1 inch in diameter and stainless-steel construction. The transducer’s ASIC design offers accuracy to 0.25% full scale, long-term stability of 0.1% per year and thermal stability that is accurate to within 1.0% per 100 F over the compensated temperature range of -40 to 250 degrees F. The series is offered in pressure ranges from 100 to 30,000 psi and in a range of outputs, pressure fittings and electrical connectors.
Setra Systems, Inc.
www.setra.com
