Pressure sensors
The PT4300 sensor is a stainless steel pressure sensor for use in such processes as oil and gas, refrigeration, gas compression and test stands.
By Plant Engineering Staff June 24, 2008
The PT4300
The PT4300 sensor is a stainless steel pressure sensor for use in such processes as oil and gas, refrigeration, gas compression and test stands. The sensors are UL/cUL 1604 (CSA 213) Class I, Div 2, Groups A, B, C and D approved for hazardous area applications. The construction of these sensors without o-rings or welds, allows them to bear pressure ranges of up to 10,000 psi with a burst pressure of up to 20,000 psi. Turck Inc.
www.turck.us
