Power supply
A new type of central power supply for ACOPOSmulti drive systems is designed for mains input voltages from 380-500 Vac. They provide continuous power output of 8 kW or 16 kW depending on the type. The high peak power rating of 24 kW or 48 kW is especially useful for dynamic applications such as packaging and printing.
October 1, 2009
A new type of central power supply for ACOPOSmulti drive systems is designed for mains input voltages from 380-500 Vac. They provide continuous power output of 8 kW or 16 kW depending on the type. The high peak power rating of 24 kW or 48 kW is especially useful for dynamic applications such as packaging and printing. In this way, fast accelerations and high speeds are possible with comparatively small dimensions. The mains connection is made using an external upstream line filter that meets corresponding EMC guidelines.
B&R Automation
www.br-automation.com
