Power supply
The CSG2400C provides 100 A continuous at 45 C and has a 150 A peak rating to insure operation in the startup of heavy loads. Features include short circuit, overload, over temperature, input/output overvoltage protection and like most ASI power supplies, it is UL508 listed. With an efficiency rating greater than 92%, you can be assured of a lot less power dissipation compared to other power su...
By Plant Engineering Staff June 1, 2009
The CSG2400C provides 100 A continuous at 45 C and has a 150 A peak rating to insure operation in the startup of heavy loads. Features include short circuit, overload, over temperature, input/output overvoltage protection and like most ASI power supplies, it is UL508 listed. With an efficiency rating greater than 92%, you can be assured of a lot less power dissipation compared to other power supplies.
ASI , www.asi-ez.com
