Power distribution fuse block
The power distribution Class J fuse block uses up to 50% less panel space and decreases installation time and labor by 33% by reducing the number of components required in the circuit.
April 30, 2014
The power distribution Class J fuse block uses up to 50% less panel space and Class J fuse blockdecreases installation time and labor by 33% by reducing the number of components required in the circuit. This patented product is available with ratings of 100, 200, and 400 amps, making it ideal for heating, ventilation, and air conditioning applications. The new power distribution fuse block is available in 1-, 2-, and 3-pole versions with individual pole versions having a dovetail feature that allows point-of-use assembly depending on the number of poles. With a smaller footprint and a 200 kiloamps (kA) withstand rating, the product helps panel builders achieve a higher assembly Short Circuit Current Rating (SCCR) for compliance with National Electric Code Sections 110.10, 409.22, 440.4(B), 670.3(A)(4), and 670.5.
 Eaton Bussmann
 www.eaton.com
