Position sensor
The Temposonics MT magnetostrictive position sensor is designed to be embedded in welded or tie-rod cylinders.
By Plant Engineering Staff April 25, 2008
The Temposonics MT magnetostrictive position sensor is designed to be embedded in welded or tie-rod cylinders. The sensor provides a measuring range of 50 to 1,500 millimeters and has a linearity of less than 0.04% FS and repeatability less than 0.005% FS. The sensor can operate over the temperature range required by most mobile hydraulics applications.
MTS Systems Corp.
www.mtssensors.com
