Portable air condition
MovinCool portable air-conditioning units can help prevent mold and mildew damage. The spot-cooling technology effectively aids in drying out and dehumidifying mold-prone areas on an ongoing basis, or in the event of a disaster when damage occurs from leaks or flooding. The fast-drying setup uses high volume warm air to extract moisture much faster than using fans or dehumidifiers alone.
By Staff August 1, 2006
MovinCool portable air-conditioning units can help prevent mold and mildew damage. The spot-cooling technology effectively aids in drying out and dehumidifying mold-prone areas on an ongoing basis, or in the event of a disaster when damage occurs from leaks or flooding. The fast-drying setup uses high volume warm air to extract moisture much faster than using fans or dehumidifiers alone. The Office Pro series is used in low-temperature conditions, while the Classic Plus series is suited for higher temperature applications.
MovinCool
www.movincool.com
