JOIN US FOR OUR FALL VIRTUAL TRAINING WEEK EVENT OCTOBER 18 - 22 - REGISTRATION IS OPEN! Save Your Spot
Lubrication
Pneumatic line expanded with tubing, fittings
The NITRA line of pneumatic components has been expanded with tubing and fittings, as well as blowguns and aluminum manifolds.
February 20, 2012
The NITRA line of pneumatic components has been expanded with tubing and fittings, as well as blowguns and aluminum manifolds. Available in 100-ft and 250-ft lengths, Nitra 16 mm polyurethane tubing has a shore A 98 hardness rating, provides outside diameter tolerance and kink resistance. Nitra brass adapter fittings and plugs are available in 10 different styles to meet most pneumatic applications such as air, water, oil, oxygen, nitrogen, and argon. Also added are quick-disconnect fittings, which allow easy changing of tools or hose connections. Nitra aluminum manifolds withstand maximum pressure up to 500 psi and are available in two styles. Nitra blowguns (or nozzles) are available in heavy-duty palm type with safety tip, pistol grips (aluminum and plastic models), pocket, and plastic grip with flexible nozzles in various lengths.
AutomationDirect
www.automationdirect.com
