Plug connector system offers connection choices
By Plant Engineering Staff November 8, 2006
COMBI plug connectors, is a modular‘plug-and-play’ system available in three connection technologies:screw, spring and IDC.It is the latest addition to the Clipline Complete System, and its connectors plug into any DIN-mounted pluggable terminal blocks, regardless of the connection technology.
The connector system uses the same plug-in zone in all basic terminal blocks, whatever the connection technology.The standard plugs (UP, SP, QP) feature the wire exit on top, while plugs with screw and spring-cage technology (UPBV, SPV) feature additional plugs with side wire exit.
Standardized bridging, marking and testing accessories are available.The user can choose between two options for wire entry: the space-saving top entry, or the low-profile side entry.The system allows quick change or replacement in plug-and-play applications.Plugs are available in pre-assembled position sizes or individually for self-assembly, enabling the user to create unique solutions based on application requirements.
Phoenix Contact Inc.
www.phoenixcon.com
