Plasma cutter handles 3/8-in. thick metal
Pro-Cut 25 plasma cutting system generates a tight cutting arc with excellent speeds and low dross levels. The system cuts through 3/8-in thick metal, and weighs only 35 lb.
By Staff November 1, 1999
Pro-Cut 25 plasma cutting system generates a tight cutting arc with excellent speeds and low dross levels. The system cuts through 3/8-in thick metal, and weighs only 35 lb. The PCT 20 torch operates without high frequency, which virtually eliminates any operating delay when the trigger is depressed or the arc is reignited.
The Lincoln Electric Co.; www.lincolnelectric.com
TO VOTE, WRITE 22 ON BALLOT
For more information, circle 59 on card
