PLANT ENGINEERING COST INDEX* – 1998-09-01
Change, % Current Month Year Facilities group index ago ago Clay construction products 144.9 0.2 1.1 Electric devices 147.9 0 1.5 Foundry and forge products 135.2 0.1 0.6 Glass 107.9 0.7 -0.2 Gypsum products 179.9 2.3 6.
Change, %
Current Month Year
Gypsum products 179.9 2.3 6.2
Heating equipment 153.2 -0.4 0.3
Lumber 178.5 1.7 -10.3
Plywood 157 4.3 -3.4
Millwork 170.9 -0.2 -0.3
Paint 155.3 0.2 1.9
Copper-based alloy rod 164 -0.8 -18.8
Pipe, steel 92.7 0 0
Plumbing fixtures 175.4 -0.2 0.3
Sash, metal frame trim 161.6 0.2 0.2
Sheet metal products 142.5 -0.1 1.1
Structural metal products 138.8 -0.2 2.4
Tanks, metal 124.8 0.1 1.6
Wire, steel 108.1 0 -0.1
Wiring devices 154.9 -0.1 0.3
Valves 158.1 0 1
Material component 150.2 0.3 -1.3
Labor component 139 0 2.8
Facilities index 143.5 0.1 1
Change, %
Current Month Year
Equipment group index ago ago
Abrasives 144 0 0.9
Bearings 162.1 0.7 1.8
Belting 148.3 0.5 1.4
Bolts, nuts, screws 128.6 0 1.3
Hand tools, mechanical 165.2 0 1.2
Lubricants 128 3.7 -0.8
Metals (steel products) 114.9 0.2 -1.2
Metals (nonferrous) 121.1 -3.8 -13.3
Metal products (miscellaneous) 126.4 -0.2 0.2
Motors 145.2 -0.3 0.3
Power transmission equipment 157.5 0.1 1.7
Precision tools 152 0 0.9
Pumps 159 -0.1 2.4
Tools, cutting 139.4 0.3 1.8
Wire and cable (nonferrous) 141.4 0.1 -5.9
Wiring devices 154.9 0.5 0.3
Valves 158 0 1.1
Material component 142.7 0.3 -0.2
Labor component 158.7 -0.2 2.8
Equipment index 152.6 0 1.7
Plant Engineering Cost Index 149.7 0.1 1.5
* Base year = 1982
