Pipe inspections made easy with portable unit
BTX Quick-Look is an ideal solution when quick inspections are needed inside 1.5 to 24-in. diameter pipe. It is stored on an integrated slip-ring cable reel/camera control unit that is 12 in. in diameter and weighs 17 lb.
By Staff April 1, 1998
BTX Quick-Look is an ideal solution when quick inspections are needed inside 1.5 to 24-in. diameter pipe. It is stored on an integrated slip-ring cable reel/camera control unit that is 12 in. in diameter and weighs 17 lb. High resolution color images are viewed on an onboard 4-in. LCD monitor. The system receives its power from rechargeable batteries.
Visual Inspection Technologies, Inc.
