Pipe coupling
The Style 177 QuickVic flexible coupling has no loose parts and requires no disassembly before installation. Using hand tools or an impact wrench, the coupling fits onto the ends of a pipe, fitting or valve. The coupling features EHP gasket material for performance from -30 to 250 F and is designed for applications rated up to 1,000 psi.
The Style 177 QuickVic flexible coupling has no loose parts and requires no disassembly before installation. Using hand tools or an impact wrench, the coupling fits onto the ends of a pipe, fitting or valve. The coupling features EHP gasket material for performance from -30 to 250 F and is designed for applications rated up to 1,000 psi. The coupling is available in 2-inch, 2
Victaulic www.victaulic.com
