Passive harmonic filter line
The FN3415 passive harmonic filter is ideal for 60 Hz, 480 or 600 VAC applications.
By Schaffner EMC July 6, 2016
The FN3415 passive harmonic filter is ideal for 60 Hz, 480 or 600 VAC applications. Courtesy: Schaffner EMCThe FN3415 passive harmonic filter is ideal for 60 Hz, 480 or 600 VAC applications. Available in various NEMA enclosures, they are easily installed and commissioned, providing immediate benefit to the electrical system by limiting the amplitude of the current harmonics, reducing losses, and allowing equipment to operate more efficiently with a longer service life. The passive harmonic filters are ideal for use with virtually any kind of power electronics with front end six-pulse rectifiers including non-linear loads such as motor drives/VFDs, factory automation equipment, fans, pumps, chillers and other HVAC equipment, DC fast chargers, mission critical systems/datacenters, water/wastewater processing equipment, oil and gas drilling and more.
Schaffner EMC
www.schaffnerusa.com
