Paint absorbs rust
Rust-Nix absorbs rust into the enamel paint pigments, then seals the surface with a bright, high-gloss finish that prevents further corrosion. Just brush off loose rust and paint. Once dry, the coating does not chip, peel, blister, or fade.
By Staff April 1, 1998
Rust-Nix absorbs rust into the enamel paint pigments, then seals the surface with a bright, high-gloss finish that prevents further corrosion. Just brush off loose rust and paint. Once dry, the coating does not chip, peel, blister, or fade. It can be applied by brush, roller, or spray on all metal surfaces.
Revere Products
Want this article on your website? Click here to see how ContentStream® can make that happen.
