Optimizing production processes with radar technology
Non-contacting radar level transmitters can help food manufacturers increase product quality, throughput and safety.
- Learn about the role radar level transmitters play in manufacturing facilities.
- Learn about the different technology options help them communicate better.
- Understand how they have evolved and what they can do for manufacturers today.
Process safety insights
- Radar level transmitters are evolving and can help food and beverage and others in process manufacturing facilities be safer and improve throughput.
- These technology advances are improving storage tanks, mixing, blending and making the cleaning processes better than before.
Automated level measurement solutions play an important role in enabling food manufacturers to achieve the production efficiency gains needed to maximize profitability and meet consumer demand. To help ensure that the most suitable level measurement technology is selected for an application, there are certain criteria that need to be considered.
Being able to continuously measure product level in storage, mixing and batch tanks as accurately and reliably as possible is crucial. Precise level measurements help to ensure consistent product quality, increase safety by protecting against overfills and dry-running pumps, optimize tank utilization and inventory management, and reduce product waste and production costs.
Level measurement instruments must also comply with the industry’s strict hygiene and food safety standards and need to be compatible with challenging process conditions – such as high temperatures, foam and turbulence – which can affect measurement accuracy. Devices need to be cost-effective, to help ensure a fast return on investment, and should also be easy to install and integrate into an automation system, to minimize complexity.
Radar level transmitter technology options
A broad range of technologies can provide continuous level measurements, including differential pressure transmitters, capacitance probes and ultrasonic transmitters. While these technologies are relatively inexpensive they do have certain disadvantages. These can include requiring calibration, which increases complexity; being in contact with the product, thereby creating a food safety risk; and being susceptible to changes in process conditions such as density and temperature affecting their measurement accuracy.
Non-contacting radar level transmitters provide some significant advantages when compared to other technology options. They are top-mounted and do not touch the product surface, thereby minimizing the risk of contamination, while changes in product density, viscosity and temperature do not affect their accuracy. The use of frequency modulated continuous wave (FMCW) technology and smart algorithms maximizes their measurement accuracy and reliability, even when used in space-constrained skids and challenging, fast-filling vessels. They do not require calibration, and have minimal maintenance requirements thanks to their lack of moving parts.
For many years, this technology has provided accurate measurements in safety-critical industries such as oil and gas, but devices have typically been considered too bulky and costly for use in food production. However, the latest generation of instruments have been designed specifically for food and beverage applications, and can meet previous industry concerns about size and cost.
Here are some examples of how these innovative transmitters are already providing significant benefits for food manufacturers.
Storage tanks
Radar transmitters rely on reflected signals – known as echoes – to perform level measurements. The latest non-contacting level devices use fast sweep technology to provide a continuous echo against the product surface. This enables them to collect up to 40 times more information than legacy instruments, which makes their measurements more accurate. Maintaining precise control of product levels in storage tanks helps to keep processes running smoothly, and avoids product wastage. This is because inaccurate measurements can sometimes result in tanks being falsely identified as empty, and large volumes of product being washed away during cleaning processes.
Another important challenge is to maximize tank utilization. The design of the latest non-contacting radar level transmitters enables them to perform accurate measurements to the very top of the tank, where there would previously have been a dead zone. This optimizes tank utilization and production capacity, helping to increase throughput, meet customer demand and improve profitability.
Mixing and blending
Level measurement devices face a range of challenges in mixing and blending applications, including turbulence, foam, and obstacles such as agitators in the tank. To meet these challenges, the latest non-contacting radar level transmitters use 80 GHz FMCW technology on a single electronic chip with embedded smart algorithms. This enables exceptional radar beam focusing, so that tank obstructions can be avoided and greater measurement accuracy and reliability achieved, even with such challenging process conditions.
A small footprint is important in food production, where many skids have tight piping arrangements. As previously mentioned, non-contacting radar level transmitters have traditionally been viewed as too bulky to use in food applications. However, with the latest devices incorporating electronics on a single chip rather than having a separate circuit board, their design has become much more compact and cost-effective, making them a good solution in space-constrained skids. Reducing complexity is important for food producers, so the integration of level measurement devices with any automation system should be as straightforward as possible.
Cleaning processes
The latest non-contacting radar devices are IP69-rated and have been designed with robust, easy to clean and food-graded wetted parts, so that their performance is unaffected during clean-in-place (CIP) and sterilize-in-place (SIP) processes. These devices have a hygienic antenna that is flush with the process connection and insensitive to condensation and build-up, ensuring the removal of process residue during CIP and SIP. In addition, their broad range of hygienic process connections fit most common tank connections and sizes. These devices are also used as part of the CIP and SIP systems, where they help to prevent overfills and dry runs, and monitor the filling and discharge of the cleaning agents.
To reduce the risk of bacteria growth, the devices have a polished stainless steel housing with minimal crevices, enabling water and sediments to drain from their body when the outside of a tank is washed down.
Felix Glans is a solutions manager for Emerson’s radar level business. This originally appeared on Control Engineering Europe’s website. Edited by Chris Vavra, web content manager, CFE Media and Technology, cvavra@cfemedia.com.
MORE ANSWERS
Keywords: radar level transmitter, process safety
CONSIDER THIS
How do you use radar level transmitters in your facility?
