Onboard intelligence provides condition monitoring for process pumps
The i-FRAME provides operations personnel, maintenance managers, and reliability engineers with early warning of trouble so that changes to the process or machine can be made before failure occurs.
By Plant Engineering Staff February 15, 2008
Announced to the trade press in a Web conference last week, the i-FRAME provides operations personnel, maintenance managers, and reliability engineers with early warning of trouble so that changes to the process or machine can be made before failure occurs.
The unit’s stainless-steel condition monitor is placed atop the power end of the pump to measure critical vibration and temperature readings. Variations that exceed preset parameters activate an early warning system by displaying flashing red lights
Available as a standard feature on Goulds’ popular model 3196 pump, the patent-pending unit’s design incorporates many other standard features designed to increase reliability and life of the pump. Premium severe-duty thrust bearings are designed to increase fatigue life by two to five times that of standard bearings. Dual stainless-steel, bronze bearing isolators improve corrosion resistance and contaminant exclusion, and an optimized sump design improves heat transfer and collects and concentrates contaminants away from bearings.
