On-board lubrication and greasing monitor
LUBExpert creates an on-board lubrication and greasing assistant is designed to guide lube-techs before, during, and after re-greasing, resulting in optimal lubrication parameters on all assets.
LUBExpert creates an on-board lubrication and greasing assistant. Intelligent algorithms guide lube-techs before, during, and after re-greasing, resulting in optimal lubrication parameters on all assets. With only a few machine parameters, LUBExpert monitors each stroke of grease and its effect on bearing friction and temperature. Before and after bearing conditions are reported with a "Good," "Bad," or "Suspect" status report. Operators can trend friction levels before and after lubrication and generate grease consumption reports for each asset or for the entire plant.
Ludeca
