Oil-lubricated screw compressor
Suitable for applications requiring large use of compressed air, the 350 hp S 341 screw compressor is available in standard pressures of 8, 10 and 13 bar. Output capacities range from 1,119 cfm to 1,441 cfm. The unit’s horizontal pre-separation system is designed to ensure low oil carry-over in all operating phases, and the patented GM drive system, along with a multi-function regulation ...
Suitable for applications requiring large use of compressed air, the 350 hp S 341 screw compressor is available in standard pressures of 8, 10 and 13 bar. Output capacities range from 1,119 cfm to 1,441 cfm. The unit’s horizontal pre-separation system is designed to ensure low oil carry-over in all operating phases, and the patented GM drive system, along with a multi-function regulation feature, allows a valve-less oil circuit; it eliminates the need for an oil stop-valve or a check-valve.
BOGE America Inc.
www.boge.com/us
