Continue to Site
Multipump dispensing system
The GT multipump dispensing system allows multiple-liquid transfer stations to operate simultaneously from a single compressor running at 2 psi. The system features a regulator with a low-volume air pressure gauge, automatic external pressure relief and automatic shutoff, quick-connect air fittings on the manifold and each pump.
By Staff November 1, 2006
The GT multipump dispensing system allows multiple-liquid transfer stations to operate simultaneously from a single compressor running at 2 psi. The system features a regulator with a low-volume air pressure gauge, automatic external pressure relief and automatic shutoff, quick-connect air fittings on the manifold and each pump. One-touch flow control dispenses chemicals at a controlled rate.
Westcott Distribution, Inc. : www.goatthroat.com
