Multimeters for DC, temperature readings
The MM5000 and MM6000 are True RMS professional meters that provide more accurate DC readings as well as temperature and frequency settings for HVAC use
The MM5000 and MM6000 are True RMS professional meters that provide more accurate DC readings of ±0.3% and ±0.2% respectively. They include a low impedance setting to eliminate ghost voltages as well as a µA setting for checking flame sensors. The meters also have a large back lit display and analog bar graph to measure fast moving readings. Both meters are double insulated, have a rubber molding for drop protection, and are CAT IV 600V rated. The MM6000 also has temperature and frequency settings for HVAC use and a 6000-count display. MM5000N and MM6000N, which are NIST certified, are also available.
Klein Tools
