Continue to Site
Multi-wavelength LED solar simulator
The LumiSun-50 multi-wavelength LED solar simulator is designed for terrestrial photovoltaic testting and PV research applications.
By Innovations in Optics, Inc. (IOI) August 17, 2016
The LumiSun-50 multi-wavelength LED solar simulator is designed for terrestrial photovoltaic testting and PV research applications. The LumiSun-50 achieves a spatially uniform illumination field from a chip-on-board (COB), multiple-wavelength LED die array. The field of illumination is 50 x 50 mm at a working distance of 200 mm. The LumiSun-50 includes a driver/controller which individually provides constant current to each die in the COB array. Total irradiance of 1.1 sun units is provided and can be decreased to 0.1 suns. The LED light source of the LumiSun-50 is contained within an air-cooled housing that can rotate the angular beam alignment.
www.innovationsinoptics.com
