Continue to Site
Multi-pump dispensing system
The GT multipump dispensing system allows simultaneous multiple liquid transfer stations to operate from a single compressor line with only 2 psi. The pumping system is designed to expand capability and streamline operations where multiple process chemicals are dispensed. The system features a regulator with a low-volume air pressure gauge, automatic external pressure relief at 6 psi, and autom...
By Staff October 1, 2006
The GT multipump dispensing system allows simultaneous multiple liquid transfer stations to operate from a single compressor line with only 2 psi. The pumping system is designed to expand capability and streamline operations where multiple process chemicals are dispensed. The system features a regulator with a low-volume air pressure gauge, automatic external pressure relief at 6 psi, and automatic shut-off quick-connect air fittings on the manifold, as well as on each pump. One-touch flow control dispenses chemicals at a controlled rate to prevent waste, conserve inventory and produce precisely measured amounts. Flow can be continuous or adjusted to dispense liquids at rates up to 4.5 gallons per minute, depending on viscosity.
Westcott Distribution, Inc.
www.goatthroat.com
