Multi-function I/O module
The USB-4716 is specifically designed for use in industrial environments and includes a USB connector with screw fasteners and a DIN-rail mounting kit. Drawing power directly from the USB port, it does not require an external power supply. It includes 16x single-ended (8x differential) inputs with 16-bit resolution, 200 kS/s analog inputs, 2x 16-bit analog outputs, 8x digit inputs, 8x digital o...
The USB-4716 is specifically designed for use in industrial environments and includes a USB connector with screw fasteners and a DIN-rail mounting kit. Drawing power directly from the USB port, it does not require an external power supply. It includes 16x single-ended (8x differential) inputs with 16-bit resolution, 200 kS/s analog inputs, 2x 16-bit analog outputs, 8x digit inputs, 8x digital outputs and a 1x 32-bit event counter. It’s furnished with WaveScan, a trending and data logging software program.
Advantech Corporation, eAutomation Group
Advantech Corporation is a CSIA member as of 2/26/2015
