Mufflers reduce air noise
Pneumatic mufflers reduce noise levels as much as 20 dB, depending on the insert, airflow rate, and mechanical noise. The housings are made of Nylon 6,6 and 33% fiber glass for strength and temperature and abrasion resistance.
By Staff December 1, 1999
Pneumatic mufflers reduce noise levels as much as 20 dB, depending on the insert, airflow rate, and mechanical noise. The housings are made of Nylon 6,6 and 33% fiber glass for strength and temperature and abrasion resistance. The insert minimizes backpressure. Sizes range from 1/8-1-in. NPT.
3M Bonding Systems Div.
www.3m.com/bonding
Circle 393
