Monitor detects water in lubricants
Hydrolert detects water in lubricating oils before damaging levels are reached, which helps extend bearing and gear life. Oil changing or filtering occurs only when needed, based on the quality of the lubricant.
By Staff August 1, 1999
Hydrolert detects water in lubricating oils before damaging levels are reached, which helps extend bearing and gear life. Oil changing or filtering occurs only when needed, based on the quality of the lubricant. Productivity is increased and maintenance costs are reduced. The device is battery-powered and installs in less than 5 min.
Trico Mfg. Corp.
Circle 393
