Modular test device for surge products
The Checkmaster 2 modular test devices checks protective elements such as spark gaps, gas-filled sure arresters, voltage-dependent resistors, and suppressor diodes in a single test cycle.
The Checkmaster 2 modular test devices checks protective elements such as spark gaps, gas-filled sure arresters, voltage-dependent resistors, and suppressor diodes in a single test cycle. The Checkmaster’s test results are recorded electronically in accordance with the IEC 62305 lightning protection standards and saved to internal memory with power supply failure protection. It features a barcode scanner and keypad for easy operation, automatic documentation of test results, and an option for manual entry of circuit identification.
Phoenix Contact
www.phoenixcontact.com
