Metering system eliminates vapor lock
PurgeX motor driven metering system for a wide range of liquids and chemicals can be adjusted from 1-0.012 cu in./stroke. The common problems of vapor lock and cavitation are eliminated by completely ejecting all air and impurities with each stroke.
PurgeX motor driven metering system for a wide range of liquids and chemicals can be adjusted from 1-0.012 cu in./stroke. The common problems of vapor lock and cavitation are eliminated by completely ejecting all air and impurities with each stroke. Buna N and Viton seals are used throughout for positive sealing.
Oil-Rite Corp.
www.thomasregister.com/oilrite
