Metalworking lube
Accu-Lube LB4600 is a natural, environmentally safe metalworking lubricant recommended for MQL operations in non-ferrous machining processes such as sawing and machining of aluminum.
Accu-Lube LB4600 is a natural, environmentally safe metalworking lubricant recommended for MQL operations in non-ferrous machining processes such as sawing and machining of aluminum. The base oil is made from renewable vegetable resources and contains no mineral oil. It is non-staining, virtually odorless and is easily burned off during the heat-treating process. The environmentally safe, non-toxic and biodegradable lubricant provides longer saw blade and cutting tool life and less machine maintenance. It is available in 1- and 55-gallon containers
ITW ROCOL North America
www.rocolnorthamerica.com
