Metal ratchets for use in tight areas
The Wera Zyklop metal ratchets feature a 72-tooth ratchet mechanism with low return angle of 5 degrees to allow for fast and precise work in small spaces.
By AutomationDirect April 15, 2016
The Wera Zyklop metal ratchets feature a 72-tooth ratchet mechanism with low return angle of 5 degrees to allow for fast and precise work in small spaces. Courtesy: AutomationDirectThe Wera Zyklop metal ratchets feature a 72-tooth ratchet mechanism with low return angle of 5 degrees to allow for fast and precise work in small spaces. The ratchets come in 1/4 ", 3/8 ", and 1/2 " drive sizes. The ratchet head is fitted with a switch lever for convenient change of direction and a ball lock securely holds sockets and attachments ensuring safe operation. The ratchet’s slim design and forged, chrome-molybdenum steel construction has no torque limitation and is ideal for use in tight areas.
AutomationDirect
www.automationdirect.com
