Material Handling – 2001-11-01
Click the above link to see Product of the Year finalists in this category.
Note to our readers: Product of the Year finalists are listed below. To view the products, please download this pdf file this file .
Flapper diverter reduces wear and downtime
Seal Tite Gravity Diverter is a flapper design that handles dry bulk material. Features include: channeled flow; access door for flapper and seal replacement; live-loaded, wear-compensating polymer shaft seal that eliminates leakage between the flapper shaft and valve body; precision fit tolerances; and an optional clean-in-place panel for quick access to the valve interior for inspection, cleaning, or sanitation. Salina Vortex Corp.; www.svortex.com
TO VOTE, WRITE 24 ON BALLOT
For more information, write 24 on card
Forklift goes in very narrow aisles
DV8r is a front wheel steered, front wheel drive, very narrow aisle forklift. The 4000-lb capacity unit is only 47-in. wide. Features include automotive-type steering that turns the front axle/mast assembly 180 deg, not the entire chassis, resulting in operating aisles reduced to only 6 ft.-7 in. wide. The unit maintains the front loading characteristics and performance of conventional forklifts. Narrow Aisle North America, Inc.; www.tailiftusa.com
TO VOTE, WRITE 52 ON BALLOT
For more information, write 52 on card
Wheel chock improves safety
Smart Chock is an electronic wheel chock safety system that enhances loading dock operations and helps industry comply with OSHA regulations. The chock keeps both drivers and dock workers alerted to the loading status of any truck parked at the dock. Photo eyes sense if the wheel is safely choked. A lighted panel indicates the status of the chock. DL Mfg.; www.dlmanufacturing.com
TO VOTE, WRITE 63 ON BALLOT
For more information, write 63 on card
Crane control is cordless
Pendant Station radio remote controller features a removable electronic key that stores frequency, address, personality, and other programming information. Each key is color coded and labeled for a specific machine; otherwise, controllers are identical, minimizing the need for spares. Hand-held, push button controller has a tough metal housing to withstand harsh environments. They are designed to provide message security, quick response time, and accurate control of overhead cranes. Cattron-Theimeg, Inc.; www.cattron-theimeg.com
TO VOTE, WRITE 71 ON BALLOT
For more information, write 71 on card
Control limits forklift speed
Speedtroller is a digital speedometer for forklifts with an overspeed signal and alarm. When an operator reaches a threshold speed set by a supervisor, an LED flashes, and a buzzer goes off. If the speed is held for 10 sec. a 120-dB siren/alarm blasts until speed is reduced. Distance traveled, distance traveled while speeding, and percent overspeed can be reviewed by supervisors. Installation is easy on inplant vehicle. Keytroller, Inc.; www.keytroller.com
TO VOTE, WRITE 90 ON BALLOT
For more information, write 90 on card
Grid belt replaces wire belting
Series 1500 Flush Grid belt was developed as a replacement for wire belting in a variety of applications. The belt is capable of nosebar transfers as small as 0.5 in. and has 48% open area for drainage or airflow. Its open hinge design and half-round link barrels expose the hinge rods for fast, thorough cleanup. Intralox, Inc.; www.intralox.com
TO VOTE, WRITE 133 ON BALLOT
For more information, write 133 on card
Rack column moved away from forklifts
The Defender rack frame design moves the front column back 9 in. from the aisle, which reduces the amount of forklift contact. Additionally, the bottom front column is made of tubular steel, with a 3/16-in. thick wall, which is much thicker and more abuse resistant than ordinary rack. In extremely abusive applications, column protection can be added. New frame can be retrofitted to existing installations. Interlake Material Handling, Inc.; www.interlake.com
TO VOTE, WRITE 103 ON BALLOT
For more information, write 103 on card
Dock seal saves energy
Insulator dock sealing system is a 4-sided sealing system. It is comprised of the Firefighter header seal with heat dissipation technology, long-lasting vertical-motion side pads, and energy-saving Insulator bottom seal. Together, these components provide safety, durability, and environmental control. Rite-Hite Corp., Frommelt Products Corp.; www.ritehite.com
TO VOTE, WRITE 104 ON BALLOT
For more information, write 104 on card
Trolley controls overhead rail systems
iTrolley is an intelligent rail system that minimizes the starting and stopping strain associated with movement of heavy loads with bridge cranes. The operator simply begins pushing the load in the intended direction and the system responds as quickly as the operator moves. The DC, servo-driven unit masks the momentum and inertia of the overhead crane. The unit works with existing rail systems. Cobotics, Inc.; www.cobotics.com
TO VOTE, WRITE 118 ON BALLOT
For more information, write 118 on card
Portable tag locates assets
WhereTag ID II/WherePort is a system that tracks the location of assets throughout a plant. The tag transmits alternate blinks when it is within range of the WherePort. WherePort uses a magnetic exciter for the tag. It can be located indoors or outdoors and can call for tags to act differently, depending on the location in the plant. WhereNet Corp.; www.wherenet.com
TO VOTE, WRITE 179 ON BALLOT
For more information, write 179 on card
Ergonomic welding station
ErgoWeld workstation, a wide-base scissors lift, features support brackets to securely hold a welding platform that allows welders to raise and lower their work to the proper ergonomic height and then safely off-load heavy loads in the lowered position. Models are available with 4000-lb and 6000-lb capacities, both with 36-in. vertical lift. Presto Lifts, Inc.; www.prestolifts.com
TO VOTE, WRITE 231 ON Ballot
For more information, write 231 on card
Vibrator uses long-life bearings
LH-Series heavy-duty hydraulic vibrators are designed to eliminate the constant failures and short life associated with needle bearings. The units use large roller and needle bearings to provide longer, trouble-free life. They offer a compact design and handle pressures up to 3000 psi. The adjustable force feature generates centrifugal force from 1000 to 5000 lb. Vibco, Inc.; www.vibco.com
TO VOTE, WRITE 203 ON BALLOT
For more information, write 203 on card
Shaft seal retains powder and bulk solids
Air Mizer-PS was developed specifically for equipment where dry particulates, powders, and bulk solids are handled. It utilizes compound labyrinth technology, enhanced with a wall of air, to function as a barrier for particulates. The design features extremely low air consumption, eliminates the need to constantly rebuild seals, and reduces the cost of unscheduled maintenance. Inpro/Seal Co.; www.inpro-seal.com
TO VOTE, WRITE 191 ON BALLOT
For more information, write 191 on card
Conveyor pulley internally motorized
MXP motorized conveyor pulleys have an internal motor and gear drive and significantly lower installation time. The AGMA Class 10, hardened and ground helical gearing reduces power consumption and noise levels. The lubricant has no recommended oil change. A magnetic particle trap reduces the risk of damage to bearings and gears. Emerson Power Transmission Corp.; www.emerson-ept.com
TO VOTE, WRITE 208 ON BALLOT
For more information, write 208 on card
Heavy-duty casters available in stainless steel
Heavy-duty, stainless steel casters are rated up to 1600 lb. Swivel and rigid models offer a broad variety of hard and soft tread wheels from 4 to 8-in. dia., including CNC-machined solid stainless steel wheels. Standard bearing selections include stainless steel precision ball bearings, plastic sleeve type, and plain bore. Hamilton Caster & Mfg. Co.; www.hamiltoncaster.com
TO VOTE, WRITE 216 ON BALLOT
For more information, write 216 on card
Smart crane reduces operator effort
G-Force Intelligent Crane Device is a servo-powered crane system that combines human control with technologically enhanced mechanical power to move large, awkward loads across the X and Y-axes with minimal human effort, helping to reduce operator injury, production downtime, and worker compensation costs. The unit can lift up to 1000 lb and operate at speeds to 275 fpm. Gorbel, Inc.; www.gorbel.com
TO VOTE, WRITE 137 ON BALLOT
For more information, write 137 on card
Conveyor control prevents product damage
E68 Series Integral Sensor Valve is an easy solution to prevent product damage and mishandling caused by outdated mechanical sensor rollers. The package comes complete with all needed components including sensors, air valves, pre-measured connectors, power supplies, and accessories. The compact power supply includes an integral junction box. Eaton Corp.,Cutler-Hammer Industrial Controls; www.sensingsolutions.com
TO VOTE, WRITE 168 ON BALLOT
For more information, write 168 on card
Drum transport includes tools
Lo-Profile Drum Caddy transports 30 or 55-gal plastic, steel, or fiber drums or two 5-gal pails that weigh up to 1000 lb. The unit rolls easily on two 6 in. x 2 in. rigid and one 3 in. x 1 in. swivel rubber casters. Straddle width is 26 in. and depth is 16 in. The handle easily detaches and features a bung nut wrench, seal remover, and drum-tipper. T&S Equipment Co.; www.tseq.com
TO VOTE, WRITE 234 ON BALLOT
For more information, write 234 on card
