Mass flow controllers
Mass flow controllers provide gas flow control for OEM and process use.
By Alicat June 11, 2015
Mass flow controllers provide gas flow control for OEM and process use. Courtesy: AlicatThe line of mass flow controllers are designed for original equipment manufacturer and process integration. They are ideal for use in OEM gas analyzers, automated gas mixing on process lines, and anywhere basic mass flow-only control is required. All the units are ready to control process flows at full accuracy in 70 ms. A 100 ms control response enables BASIS to react in real time to upstream fluctuations. NIST-traceable accuracy is +/-(1.5% of the reading + 0.5% full-scale). The controllers are available with the following calibrations: Air, Ar, CO2, N2, O2, N2O; He, H2 are also available in single-gas units.
Alicat
www.alicat.com
Want this article on your website? Click here to see how ContentStream® can make that happen.
