Maintenance Tips & Tricks – 2000 – #18
Calculating bits Problem: Is there an easy method for figuring out what size drill bit to use for tapping a metric hole? Solution: Simply subtract the thread pitch from the metric screw size and you have the answer. For example, to tap an 8-mm hole with a thread pitch of 1.25, the proper drill bit is 6.75 mm. Contributor: Fred Hoefer, Electronics Mechanic, CIBA Vision Corp., Duluth, GA; fred.hoefer@ cibavision.Novartis.com. List of Tips & Tricks |
Plant Engineering |
