Maintenance Tips & Tricks – 2000 – #11
Finding leaks Problem: You are pretty sure that a flange in gas service is leaking. How can you prove it? Solution: Take a piece of 2-in.-wide masking tape and wrap it around the flange connection. Poke a pinhole in the center of the tape. If the flange is leaking, gas can only escape through that point. Apply a soap and water solution to the pinhole. If bubbles or foam appear, the flange is leaking. Contributor: Ralph Dewey, Solvay Polymers, Deer Park, TX; 713-307-3784
List of Tips & Tricks |
Plant Engineering |
